whoahorse Posted May 10, 2004 Posted May 10, 2004 Hey all! I am having problems finding the area in the admin section for our forum that allows people to post images. Our forum is http://www.whoahorse.com/forum Thanks! Weezy Quote
TCH-Bruce Posted May 10, 2004 Posted May 10, 2004 2 things to check 1. In the admin of security & privacy you must have the radio button in the (low) security settings to allow images to be posted set to "yes" 2. Make sure you set the uploads folder to 777 permissions Quote
whoahorse Posted May 10, 2004 Author Posted May 10, 2004 2. Make sure you set the uploads folder to 777 permissions Thanks for your post! Where do you find that uploads folder? Weezy Quote
TCH-Thomas Posted May 10, 2004 Posted May 10, 2004 In either cpanels file manager or through an ftp program its the last sub-folder in your forums-folder. Quote
whoahorse Posted May 10, 2004 Author Posted May 10, 2004 In either cpanels file manager or through an ftp program its the last sub-folder in your forums-folder. Thanks! I wonder how I change the settings of it? Weezy Quote
LisaJill Posted May 10, 2004 Posted May 10, 2004 Choose the folder and click the text link (not the actual folder image), to the right you should get a list of options, one is change permission. Just type the numbers you want in the lowest row. =) Quote
whoahorse Posted May 10, 2004 Author Posted May 10, 2004 Thanks Lisa! I did find that 777 thing. Images still not allowing.. WAH! Weezy Quote
TCH-Don Posted May 10, 2004 Posted May 10, 2004 My check list for allowing fourm uploads for IPB Board settings > Security and Privacy > Allow images to be posted? YES forum control, edit permissions for each forum, allow upload checked. users and groups > manage user groups > edit group, Max upload file size (in KB)= reasonable size (disable this groups upload by entering 0 into this field. This will turn off the mutli-part form the uploads use. ) (default is 0, I use 100 ) users and groups > manage user groups > edit forum access, allow upload for each forum. with ftp, Folder Uploads permissions set to 777 Quote
whoahorse Posted May 10, 2004 Author Posted May 10, 2004 THANK YOU EVERYONE!!! YAYYYYYYyyy... I think it was my forum access I forgot to fix. THANKS Don! Boy this place is the best! Rock Sign We need a new sign. I am going to go make it right now. LOL Weezy Quote
TCH-Don Posted May 10, 2004 Posted May 10, 2004 You can find more IPB forum mods in Third Party Script Tutorials Quote
whoahorse Posted May 10, 2004 Author Posted May 10, 2004 You can find more IPB forum mods in Third Party Script Tutorials Don, you should write a book. You and Lisa. LOL PHP for Dummies. hehe Thanks again! Weezy Quote
LisaJill Posted May 10, 2004 Posted May 10, 2004 I can't program php you know... I will be able to by the time summer is over, though. =) Quote
TCH-Bruce Posted May 10, 2004 Posted May 10, 2004 forum control, edit permissions for each forum, allow upload checked. users and groups > manage user groups > edit group, Max upload file size (in KB)= reasonable size (disable this groups upload by entering 0 into this field. This will turn off the mutli-part form the uploads use. ) (default is 0, I use 100 ) users and groups > manage user groups > edit forum access, allow upload for each forum. I knew there were more, but I couldn't find them. Thanks Don. Quote
whoahorse Posted May 11, 2004 Author Posted May 11, 2004 Lisa - I bet you could do anything you put your mind to. Thomas... this image? he he Quote
whoahorse Posted May 11, 2004 Author Posted May 11, 2004 Yup LOL! Thomas! I think I will be using that one alot. Weezy Quote
