annie Posted May 8, 2004 Share Posted May 8, 2004 I installed this from the control panel (just got my account), but this is the error I get: Warning: main(./sources/functions.php): failed to open stream: No such file or directory in /home/username/public_html/wboard/index.php on line 114 So, how do I get hold of this, and get the board working? Quote Link to comment Share on other sites More sharing options...
TCH-Thomas Posted May 8, 2004 Share Posted May 8, 2004 Not sure if this is needed when you install from cpanel, but did you create a mysql database? (Wait for a tech person to answer that). Only other thing i can think of is to kill it and create a new one to see if same error shows up again. Quote Link to comment Share on other sites More sharing options...
annie Posted May 8, 2004 Author Share Posted May 8, 2004 The most relevant info I found while searching the net was this: http://forums.invisionpower.com/index.php?...t=entry851469 If this is what created the problem, then installing again won't fix it, until they've changed the auto-installer on that server. Or if I can somehow replace that file. And yes, I have created a database. Granted, after I installed the forum, but I did go through the install after I got the name of the database, username and password. The only other source of error is that my domain name still isn't active. But I need to get the forum up and running WAY before I redirect the domain name, so I need to bypass that if that's why it's not wokring. Quote Link to comment Share on other sites More sharing options...
TCH-Thomas Posted May 8, 2004 Share Posted May 8, 2004 until they've changed the auto-installer on that forum Then you would need to open a support ticket, which i thinks is best after reading that thread you mention. Link is on top of page. Quote Link to comment Share on other sites More sharing options...
TCH-Dick Posted May 8, 2004 Share Posted May 8, 2004 The most relevant info I found while searching the net was this:http://forums.invisionpower.com/index.php?...t=entry851469 That can not be the problem as TCH servers do not run in safe mode. Quote Link to comment Share on other sites More sharing options...
annie Posted May 8, 2004 Author Share Posted May 8, 2004 Don't know what they did, but it's fixed! Quote Link to comment Share on other sites More sharing options...
TCH-Dick Posted May 8, 2004 Share Posted May 8, 2004 Glad its working. If you have anymore problems just let us know. Quote Link to comment Share on other sites More sharing options...
TCH-Thomas Posted May 8, 2004 Share Posted May 8, 2004 Don't know what they did, but it's fixed! Their magic Quote Link to comment Share on other sites More sharing options...
annie Posted May 8, 2004 Author Share Posted May 8, 2004 I wish. After functions.php was added, there were a lot more missing files, unfortunately. Right now I wish I had a zip file of the whole board, so I could replace any missing files manually. Admin works, but that's about it right now. Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted May 8, 2004 Share Posted May 8, 2004 You can downoad the entire installation from Invsion's site at this link: http://www.invisionboard.com/download/index.php Quote Link to comment Share on other sites More sharing options...
annie Posted May 8, 2004 Author Share Posted May 8, 2004 Didn't find that version there. Assumed they only had the non-free versions there. Hopefully I solved my problem by installing it somewhere else, then downloading the entire directory structure from the other host. We'll see. Quote Link to comment Share on other sites More sharing options...
TCH-Thomas Posted May 8, 2004 Share Posted May 8, 2004 Try this one... Link to latest stable version (1.3.1) of invision board. Quote Link to comment Share on other sites More sharing options...
annie Posted May 8, 2004 Author Share Posted May 8, 2004 To me it looks like the installer timed out. I'll see if I can fix it by adding files from an intact installation. Thanks for the link. Looks like it isn't free, though... Will have to think about that... Quote Link to comment Share on other sites More sharing options...
TCH-Thomas Posted May 8, 2004 Share Posted May 8, 2004 (edited) Its free if you accept the tiny powered by link on bottom as you see in this forum too. Edited May 8, 2004 by Jikrantz Quote Link to comment Share on other sites More sharing options...
TCH-Thomas Posted May 8, 2004 Share Posted May 8, 2004 Heres a link that says it is free: http://www.invisionboard.com/download.cgi?subc=trial The other link i posted previously goes to the latest stable release which must be free (or would it be linked otherwise ) Quote Link to comment Share on other sites More sharing options...
annie Posted May 8, 2004 Author Share Posted May 8, 2004 Thank you guys. I used the new version, temporarily renamed the forum folder. Then installed the new version, with a new database. Suddenly everything worked! Thanks for the help, it really DID make a difference! Quote Link to comment Share on other sites More sharing options...
TCH-Don Posted May 8, 2004 Share Posted May 8, 2004 Its alway good to install the latest version. If I were you, I would write down the steps and user and datbase names for future referance. It can be a guide to installing the next version and other programs with databases. Quote Link to comment Share on other sites More sharing options...
