TangentIdea Posted May 6, 2004 Share Posted May 6, 2004 One of the things that's always irritated me about Cpanel is its unnecessary use of images and HTML code. It's a total waste of bandwith. Can I make a slimmer template to use with cpanel, perferably something text-based? It would be a huge help to me and my clients (most of which are on dialup). Is that possible? -Ryan Quote Link to comment Share on other sites More sharing options...
MikeJ Posted May 6, 2004 Share Posted May 6, 2004 You would have to be on a dedicated server to install your own skin. As for can you create your own (if you are on a dedicated server), yes it is possible, but rather difficult as the cPanel API isn't really documented, and you would have to update them whenever cpanel made any API changes. Unless you are up for a major project, you would be better off looking at 3rd party supplied cpanel skins, some of which include slim versions. From what is available on the TCH servers, you may want to use Monsoon for your dialup clients. It has relatively minimal graphics compared to the x skins. Quote Link to comment Share on other sites More sharing options...
TangentIdea Posted May 6, 2004 Author Share Posted May 6, 2004 Yeah, monsoon is what I'm using now. Could TCH install a couple of those "slimmer" skins on our server? -Ryan Quote Link to comment Share on other sites More sharing options...
