I have been using linux (RedHat) for a long time but i am still not that familiar with it. I have heard of using something called a virtual machine. It runs on linux and emulates a different operating system. My question is, does it perform as well as runing the operating system by itself? Or better(or worse)? Thanks.
Well, you have two choices: either you use an emulator or you use a virtual machine.
Wine is the best emulator (though their creators don't like to call it an emulator. Even the name means "Wine Is Not an Emulator" :blink:) for running Windows apps. It basically takes your windows programs and executes them on Linux.
Performance really depends on the power of your machine. If you have a fast computer, you probably won't notice much difference except for when you start the application.
You can get it at winehq.com .
Then there's the other approach, which is to use a virtual machine, like VMWare or Win4Lin (www.vmware.com and netraverse.com , respectively).
A virtual machine can also be considered an emulator but at a much lower level: it doesn't emulate the operating system where the applications run; it emulates the hardware itself. So a virtual machine pretends to be the computer, allowing you to install a full operating system in it's virtual hard drive.
Personally I prefer the virtual machine method simply because Wine is too much trouble to set up and use. It's a fine piece of software but it still has too many compatibility problems.
Hope this helps.
Edited by TCH-Raul
