Greetings,
Most of the postings to my guestbook are great. However, one posting is a bit inappropriate. Can I edit out the offending portion?
Also, my initial comment is no longer pertinent. I would like to fix it up.
So, any help in editing text in the advanced guestbook will be appreciated.
Just login into the admin interface and you should be able to edit or delete any messages easily.
Is there any specific portion of it that is giving you trouble?
I am having difficulty getting into the admin functionl. Is this done from cpanel or from the guestbook on my site?
Is the admin username and password set as a default? If not, where and how do I do set-up or change this.
Usually, I can figure this out, but here I am stumpped.
Any help will be appreciated.
Steve
