!!blue Posted January 29, 2004 Posted January 29, 2004 (edited) At work I have to use BBEdit to code what I work on. With my trusty laptop beside me, Dreamweaver MX, and a memory stick it makes life a little easier. My question is in regards to this: BBEdit has a button that, when clicked, automatically makes all the tags lowercase (and another button to make them uppercase). Is there a feature like this in Dreamweaver? Helps if I want to re-code an existing page into xhtml. I'm sure I'll have more questions...and hopefully some answers too! thanks, Z Edited January 29, 2004 by !!blue Quote
borfast Posted January 29, 2004 Posted January 29, 2004 If I recall correctly, you can tell DW to automatically format the whole code for you and it will convert all tags to lowercase. I also recall seing an option in DW MX to specify if you want it to write upper- or lower-case tags when you use the WYSIWYG mode. I'm not sure what influence that option has if you chose to write an XHTML document - DW should automatically write lower-case tags. Quote
natimage Posted January 29, 2004 Posted January 29, 2004 I also recall seing an option in DW MX to specify if you want it to write upper- or lower-case tags when you use the WYSIWYG mode. Yes, this is in the Edit/Preferences/Code Format dialog box. Also, in the File menu is an option to Convert to XHTML. It doesn't convert lower-case tags to upper-case tags, that I can tell. Does XHTML have to be in upper case? I thought it was just more strict with closing tags and stuff like that. Quote
borfast Posted January 29, 2004 Posted January 29, 2004 Tracy, it's the other way around XHTML needs all tags to be lower-case - and I think DW does convert upper-case tags into lower-case. I could be wrong, though. It's been a long time since I last worked with DW. Quote
natimage Posted January 29, 2004 Posted January 29, 2004 ...shows how much I know about xhtml!!! I just checked the Convert function, and it does change all upper-case tags to lower-case tags, enters the appropriate tags at the top of the page (even for php) and fixes tags like <img> that have no closing tags in html. Seems like it does it all...and in a heartbeat, I might add!!! Quote
!!blue Posted January 30, 2004 Author Posted January 30, 2004 thanks! btw: sometimes I'm given the *lovely* task of taking an old html page/site and update it, e.g. add CSS, convert to XHTML, new images or other such stuff. later, !!blue Quote
