Im trying to set up a free for all page with cgi.
What do i fill in in this line (if domain is www.jikrantz.com if relevant)?
># base directory to all link files from the server root without trailing "/"
$base_dir = "/home/usr/you/links";
-Thomas
Should be:
>/home/username/public_html/links
I believe...this is given that you want it at example.com/links
Also, your username is whatever you use to login to CPanel :rolleyes:
:rolleyes: It/I failed, what does this mean?
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@lakewoodunicycleclub.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/1.3.29 Server at www.lakewoodunicycleclub.com Port 80
-Thomas
