I FIXED IT...SEE "FIX" BELOW!
Hi All...I'm having a problem with one of my new website pages. I probably couldn't even begin to list all I've done to fix it...but I'll give a quick rundown.
Problem is...in the right hand column of THIS PAGE I have a mix of text and images. All works fine in both IE6 and Mozilla until I put the very last image in. It goes at the bottom of the text (right column).
Once I put that last image in, Mozilla stretches my table all out of whack. IE shows it correctly...use that to see what it is supposed to look like. If I remove the image, the page presents perfectly.
Here are a few facts:
Image width is the same as the table cell width (I tried a smaller image and had the same problem).
Height and width attributes are assigned appropriately to the img tag.
Tried putting image inside <p> tags with the text...
Tried putting image outside <p> tags...
Tried putting image in it's own set of <p> tags...
Tried <div> tags...
Tried putting a break tag before the image...
Table is not set as a percentage, so it should not stretch.
I can't think of what else I have tried...I just know that "IT'S KILLIN' ME"!!!!!
Please show me the light... :)
Edited by natimage
Nevermind...I fixed it. Mozilla didn't like that there was no "align" attribute. That's all it needed.
Man...sometimes I really wish these browsers could communicate a little bit better!! woooot
