Margome Posted September 14, 2022 Posted September 14, 2022 A new SSL version is now added that showed up Sept 5. How did this happen or did I do something to make this happen? See attached photo. I am not as savvy as most here so I would appreciate any help! Does this mean I have my website two times in storage space? (Double mb) How do I keep just one? Which one should I keep or just keep both? Thank-you for any advice! Mario Quote
TCH-Dick Posted September 14, 2022 Posted September 14, 2022 Hi Margome, Traffic over HTTP and HTTPS are managed using two different ports and tracked the same via Awstats. If you are only recently seeing this then a SSL certificate now exists on your account. This can be done via the purchase of a certificate or by enabled the Let's Encrypt service in your cPanel. In your case, I checked your certifcicate and it shows to be issued by R3, which is Let's Encrypt. This feature as no affect on your storage usage but does help secure your site. I would recommend redirecting your traffic to the secure URL to be consistent. If you need help with that just let us know either here or through our help desk. 1 Quote
