Flora Adams Posted October 7, 2015 Posted October 7, 2015 (edited) Hi, people of the forums! I'm fiddling with my .htaccess file, and I've run into some issues. Before I continue, please note that I know next to nothing about .htaccess files, my apologies! Now, originally a nice support rep fixed my previous .htaccess file, using this code. <IfModule mod_rewrite.c> RewriteEngine On RewriteBase / RewriteCond %{THE_REQUEST} ^GET\ (.*)\.html\ HTTP RewriteRule (.*)\.html$ $1 [R=301] RewriteCond %{REQUEST_FILENAME}.html -f RewriteCond %{REQUEST_URI} !/$ RewriteRule (.*) $1\.html [L] </IfModule> It works splendidly! However, I wanted a trailing slash at the end of the url. With this code, it displays "websitedotcom/about," when I'd rather "websitedotcom/about/" It's a small issue, but it DOES return with an error if I try to add a trailing slash to the url. I could use permanent redirects to fix it, but I have a lot of pages to fix. So, in my quest for finding codes to add a trailing slash, I tried this code that I found online. <IfModule mod_rewrite.c> RewriteEngine On RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^([^/]+)/$ $1.html RewriteRule ^([^/]+)/([^/]+)/$ /$1/$2.html RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteCond %{REQUEST_URI} !(\.[a-zA-Z0-9]{1,5}|/)$ RewriteRule (.*)$ /$1/ [R=301,L] </IfModule> This works well too! Except for one problem. I have 2 folders and 1 subdomain. The folders are using index.html files, and I specify them in links as their directory name. (websitedotcom/directoryindex/, which is an index.html) The subdomain is for my forum, websitedotcom/forum/ Now, when I try to click websitedotcom/directoryindex/ or websitedotcom/forum/, I get a 404 error page, and I'm assuming this is because the codes I used edit out the .html file extension, add a trailing slash to it. SO, the code either doesn't find the websitedotcom/directoryindex/ folder because it's a folder, not an html file, or it's conflicting some how by editing it to websitedotcom/directoryindex// I'll use the original code for now until I find a better solution. It's not exactly a dire problem, I was just curious as to why the new code conflicts with directory index files, and what a possible fix would be in order to display index files properly, while still having other html pages having a trailing slash. Thanks in advance. Edited October 7, 2015 by Flora Adams Quote
TCH-Alex Posted October 7, 2015 Posted October 7, 2015 Please try this rule before your other rules:RewriteRule ^(admin|forums)($|/) - [L] This will end the rewriting process for the folders specified. Note :: I have tested this on your account and verified that http://black********.com/forums/ is working fine. Quote
Flora Adams Posted October 8, 2015 Author Posted October 8, 2015 My website works perfectly now! Thank you for the help, Alex! It's much appreciated. Quote
