Greetings, I'm trying to install the File::spec perl module onto my server on dagobah (the server, not the planet), but when I use the cPanel installation script, I get the following:
Testing connection speed...(using fast method)...Done
Ping:1 (ticks) Testing connection speed to cpan.mirrors.tds.net using pureperl...(20566.67 bytes/s)...Done
Ping:1 (ticks) Testing connection speed to mirror.team-cymru.org using pureperl...(29500.00 bytes/s)...Done
Ping:1 (ticks) Testing connection speed to mirrors.servercentral.net using pureperl...(28050.00 bytes/s)...Done
Ping:2 (ticks) Testing connection speed to mirror.cogentco.com using pureperl...(20200.00 bytes/s)...Done
Ping:1 (ticks) Testing connection speed to ftp.wayne.edu using pureperl...(19500.00 bytes/s)...Done
Five usable mirrors located
Ping:1 (ticks) Testing connection speed to 216.104.43.138 using pureperl...(28950.00 bytes/s)...Done
Ping:1 (ticks) Testing connection speed to 74.200.212.130 using pureperl...(28950.00 bytes/s)...Done
Ping:1 (ticks) Testing connection speed to 216.246.55.158 using pureperl...(28950.00 bytes/s)...Done
Three usable fallback mirrors located
Fetching http://mirror.team-c...CPAN/index.html (connected:0).......(request attempt 1/12)...Resolving mirror.team-cymru.org...(resolve attempt 1/65)......connecting to 38.229.66.100...@38.229.66.100......connected......receiving...100%......request success......Done
Mirror Check passed for mirror.team-cymru.org (/index.html)
Checking C compiler....Could not locate an executable "cc" binary....Done
** Unrecoverable Error **
The C compiler is not functional and auto repair failed.
Perl module installs require a working C compiler.
Please repair the C compiler and try again.
Am I doing something wrong? This is a server-side issue, yes?
