kcraighead 1 Posted December 13, 2011 Share Posted December 13, 2011 (edited) I am using the exit() command in one of my scripts and it is being ignored. Any idea why this would be? The exit() is within a function which is attempting to grab a value out of an array as follows: > function get_setup_fee($prod_id, $M_PRODS, $M_SETUP ) { //figure out the location of the product_id in the array and get it's key $keyz = array_search($prod_id,$M_PRODS); // now we have the key we the use the same key against the setup fees to find the matching one $setup_fee = $M_SETUP[$keyz]; echo "The keyz is: " . $keyz; echo "The prod_id is: " . $prod_id; echo "M_PRODS is: " . $M_PRODS; echo "The setup_fee is: " . $setup_fee; exit(); return $setup_fee; } The $setup_fee value being returned is wrong so I want to echo the values to the screen so I can figure out the issue with the code. However the script continues to run so I can't see what the values are. Any idea why this would be? I read on another forum that in shared hosting it may be "something with either safe_mode being enabled, output buffering being enabled, or error_reporting being enabled.". Anyone know anything about that? Thanks for the help! Hi! I am the guy behind NetChimp, a web design company. NetChimp offers Web Design York and Web Design Aberdeen plus SEO York and are known as a good Small Business Web Designer with a website packed with Good Web Design Examples. Edited December 13, 2011 by kcraighead Quote Link to post Share on other sites
TCH-Dick 25 Posted December 13, 2011 Share Posted December 13, 2011 Your function is just returning the value of $setup_fee and wouldn't pass along exit() to the rest of the script. Just temporarily add exit() directly after you echo the returned value of get_setup_fee(). Quote Link to post Share on other sites
OJB 0 Posted December 14, 2011 Share Posted December 14, 2011 You could also try changing all your 'echo' statements to error_log() function calls. Like so: > error_log('The keyz is:' . $keyz); error_log('The prod_id is: ' . $prod_id); error_log('M_PRODS is: ' . $M_PRODS); error_log('The setup_fee is: ' . $setup_fee); Then check your php error log to see what has been written to it. Quote Link to post Share on other sites
