I downloaded and am trying to install the FFAL-script from http://www.proxy2.de/
All gone as expected except this
"Cannot create ID file http://www.jikrantz.com/whoops/links/links_id.txt in http://www.jikrantz.com/whoops/links/links_id.txt. Please check your base directory."
What am I doing wrong?
-Thomas
P.S First time I post a script problem here, so let me know if you need more info.
Hi Thomas.
Using CPanel's File Manager, change the permissions of your "/public_html/whoops/links/" directory to 777.
It seems that using the numbers sometimes messes things up, so if you end up with different permissions, use the check boxes instead. 777 is equivalent to checking all the boxes.
This should do the trick :blink:
Well, if it says 755, it's better to use 755. I said 777 because I had just replied to another thread where George needed to use 777, so I guess I was in the modd :goof:
Edited by borfast
