laurin1 Posted January 22, 2010 Share Posted January 22, 2010 We are having trouble making a remote connection from our local PHP site to the TCH MySQL server. This is the errors we are getting: WARNING [2] mysql_connect(): OK packet 6 bytes shorter than expected, Line: 34 in file C:\inetpub\local_intranet\website_updater.php WARNING [2] mysql_connect(): mysqlnd cannot connect to MySQL 4.1+ using old authentication, Line: 34 in file C:\inetpub\local_intranet\website_updater.php I've had this issue locally before, and fixed it....somehow (can't find my notes), but we cannot figure this one out. We've reset passwords. We're using PHP 5.3.1. Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted January 22, 2010 Share Posted January 22, 2010 Not sure if this will help. Or this. Quote Link to comment Share on other sites More sharing options...
laurin1 Posted January 22, 2010 Author Share Posted January 22, 2010 Not sure if this will help. Or this. Well, the problem with every solution that I have found, is that we do not have access to the USER tables, except by interface in CPANEL. For instance: To fix this error I did the exact opposite of what that website says. What happens is that MySQL had the password stored in the old format, change the password to the new format. To check this, open the MySQL console (mysql.exe in Windows) and run: SELECT Host, User, Password FROM mysql.user; If the Password column is a 16-digit hexadecimal number, then the password is in the old format. Then you have to execute: SET PASSWORD FOR 'your_user'@'your_host' = PASSWORD ( 'your_old_password'); Where your_user is the user name and your_host is the hostname as appear in the corresponding columns and your_old_password' is the old password stored without encription (plain text). That solved my problem. I get access denied, whether remote or via PHPMyAdmin, to the USER table. Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted January 22, 2010 Share Posted January 22, 2010 Maybe you should open a ticket with the help desk and have then take a look at it. I find it strange that you can't access a table using phpMyAdmin through cPanel. Quote Link to comment Share on other sites More sharing options...
