dpkyte Posted September 15, 2009 Posted September 15, 2009 I downloaded the 2 files from the ZIP file on http://www.totalchoicehosting.com/help/statisticspage.htm. I then moved them over to the server under a new directory called stats. I enter the user id and password that are under the config file and the web page says "This page is in Filipino. Translate it using Google Toolbar". There is then a Translate button. See attached image appears. Any Thoughts? Quote
TCH-Bruce Posted September 15, 2009 Posted September 15, 2009 Try downloading the file again using this link. Then configure the script as stated in this thread. Since you are not putting it in your public_html folder did you remember to add the require_once line to your config.php file? require_once('/home/cpaneluser/safe/config.php') Quote
