sheryltoo Posted February 16, 2009 Posted February 16, 2009 (edited) I know you don't support smf, but no one there seems to be able to tell me anything so I'm hoping someone here might be able to help or point me to a place that can give me help. I've searched high and low at the smf site and searched this site for some similar problems and may have found some, only people ended up fixing their problem and never said how so that doesn't help me. So this is my problem. First of all, I'm trying to install a mod on my smf site and get this fatal error: >Fatal error: require() [function.require]: Failed opening required '/home/domain/public_html/subdomain/Packages/temp/./install1-1.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/domain/public_html/subdomain/Sources/Packages.php on line 556 I don't know what that means or how to find that exact line but after I try and install the mod, this is the error I get on my error log for smf: >2: fclose(): supplied argument is not a valid stream resource File: /home/domain[/color]/public_html/subdomain/Sources/Subs-Package.php Line: 1908 My permissions for sources/subs-package.php was 755. One of the messages I found in my search led me to believe I needed to change that permission so I changed it to 644 since that's what's set for the same file on another version smf in my primary domain folder. That didn't help so maybe that had nothing to do with it. Any help on this would be greatly appreciated. Sheryl Edited February 16, 2009 by sheryltoo Quote
TCH-Bruce Posted February 16, 2009 Posted February 16, 2009 I don't know but it's looking for a folder in your root folder denoted by [/color] in your error message above. There should be nothing writing to your root folders and that may be the source of the problem. Can you contact the author of the mod. Maybe they can shine some light in your direction. Quote
sheryltoo Posted February 16, 2009 Author Posted February 16, 2009 Thanks for trying to help me. Someone actually got back to me at the smf site after I posted this so I wanted to let you know what's going on. I've been dealing with this problem for over a week now which is why I got desperate and thought I'd ask here. Anyway, someone suggested I create a temp folder in my package folder and I "think" that might have done the trick. I was able to install a mod without getting a fatal error. I'm still not home free because something needs to be manually changed in my themes folder, but I think I can get that figured out or rather find someone who will tell me where to put some codes. But thanks again for trying to help me. Sheryl Quote
