ace Posted February 12, 2009 Posted February 12, 2009 I have a Iomega REV 35 USB drive. The drive keep ejecting the disk when it is inserted. I have tried two disks and get the same results. I have flashed the firmware, updated the REV software and even tried it on a different PC. IT just keeps ejecting no matter what I do. If I unplug the USB cable from the computer the cartridge will remain loaded- but as soon as it is plugged into the computer it ejects. I am thinking the drive has gone bad. Suggestion?? Thanks for your help Quote
ace Posted February 12, 2009 Author Posted February 12, 2009 I have a Iomega REV 35 USB drive. The drive keep ejecting the disk when it is inserted. I have tried two disks and get the same results. I have flashed the firmware, updated the REV software and even tried it on a different PC. IT just keeps ejecting no matter what I do. If I unplug the USB cable from the computer the cartridge will remain loaded- but as soon as it is plugged into the computer it ejects. I am thinking the drive has gone bad. Suggestion?? Thanks for your help By the way it is running on XP Quote
ace Posted February 19, 2009 Author Posted February 19, 2009 Power supply went bad - replaced it and now the drive is fine. Quote
TCH-Bruce Posted February 19, 2009 Posted February 19, 2009 Persistence. Glad you sorted it out. Quote
