I have searched google until I am blue in the face. A regular smurf !
I have about a 2 year old gateway that the lady blew the hdrive in.
installed new hdrive.
re-installed all the original gateway op system ( xp home )
thought everything was fine and decided to shut down, pack up and deliver.
every time I click on SHUT DOWN, it reboots.
no viruses, no spyware, new, clean install.
call me STUMPED !!
ANY IDEAS TCH 'ERS??????
OK
One problem many folks on the web were finding was ROXIO.
This gateway does not have ROXIO; but it had MUSIC MATCH.
So I uninstalled MUSIC MATCH.
xp shuts down just fine now.
Internet search solutions will give you a ton of registry edits and other such "tips" ;
but it looks to me like at least the above two music programs are culprits for sure.
thanks
Edited by mike
heh heh
You know me, Bruce...... the ol' lone wolf chatterbox.
OK I TAKE IT BACK. Last nite it shut down perfectly 4 times.
Today..........it's rebooting itself again.
AAAAAAARRRRRRRGGGGG
thanks madman, I have done everything there but the bios check which I am going to do today when I get home.
I have , however, long ago it seems, unchecked the automatic reboot and never have seen an error message when
I tell it to shutdown.
problem update :
still working
I found that somehow plug and play service was turned off.
turned it on. shut down perfectly 5 or 6 times.
now rebooting again on shutdown.
aaaaaaarrrrrrghhhhh!
Have you tried restarting from scratch? Wipe the HD and start over.
Yes, actually this is a new hdrive on which I re-installed her original gateway ( uggh ) software.
Then installed service pack 3, then anti-virus and spyware.
I DID get device manager to show me list again though.
I may have to do another install.
Ok
I did a complete format and re-install.
Then gateway drivers.
Then windows service pack 3
antivirus installed
At first it STILL rebooted on shutdown.
then I went to bios and disabled that "wake on" thing.
So far I have had 6 successful shutdowns in a row
hate to risk jumping the gun but......... :clapping:
Ok, the "wake on" setting of the gateway board is why it kept rebooting.
Problem solved.
thanks madman and everyone
