My check list for allowing fourm uploads for IPB
forum control, edit permissions for each forum, allow upload checked.
users and groups, manage user groups,
...edit group, Max upload file size (in KB)= reasonable size
(disable this groups upload by entering 0 into this field. This will turn off the mutli-part form the uploads use. )
(default is 0)
...edit forum access, allow upload for each forum.
(default is 0)
Ok i got the permissions set well they have been, I have the option checked that says allow file upload. I will check into hte rest. Thanks
Adding one more thing at the top of the list (security)
Board settings > Security and Privacy > Allow images to be posted? YES
users and groups > manage user groups >
    (default is 0, I use 100 )
