Can someone help me create a trigger for a database?
The front end GUI where the person will be sending data can not be set to send in all caps, so I am trying to do it on the back end.
Is this possible with MYSQL?
Thanks,
Adam
You say the data could be coming from anywhere, but surely you have a query at some point to add the data into the db?
So in your insert query do something like this:
>$query = ' INSERT INTO tbl_name (fld_name) VALUES(\''.strtoupper($the_value).'\')';
i.e. convert the string to uppercase as you insert it into the db
or is this not what you want?
if you want to write an update query it will be something like:
>UPDATE tbl_name SET fld_name = UPPER(fld_name) WHERE fld_name = 'blahblah'
Edited by OJB
