kryles Posted September 18, 2008 Posted September 18, 2008 I ned to connect to the database using VB.NET (2003) but I'm not sure what my server variable would be. Is it my domain name? is it an IP to the Database server? Anyone have an idea? Thanks, Quote
MikeJ Posted September 19, 2008 Posted September 19, 2008 I'm assuming you are talking about connecting to your MySQL database in a shared web account at TCH. If that's teh case your domain name would work fine for the server variable. If you find it doesn't connect, however, you will want to enter a help desk ticket. I don't believe TCH has mysql open to outside connections by default. Quote
penetamaal Posted January 16, 2013 Posted January 16, 2013 I ned to connect to the database using VB.NET (2003) but I'm not sure what my server variable would be. Is it my domain name? is it an IP to the Database server? Anyone have an idea? Thanks, check this oledb connection sample vb.net-informations.com/ado.net-dataproviders/ado.net-oledbconnection.htm vb.net-informations.com/ado.net-dataproviders/ado.net-oledbconnection.htm It will work. peneta. Quote
