Hello.
I am setting up my shipping configurations inside the Zen Cart for my website.
If I want to use third-party sites to acquire realtime shipping quotes, I need to specify certain
proxy settings in order for the "cURL" to work properly.
First of all, I am not real clear what "cURL" is, but I am willing to learn.
But the most important thing I need to know is the proper proxy settings,
and this is what they ask:
Zen Cart asks for the below information:
cURL Proxy Address
Please make any necessary changes
Here they give an example:
cURL Proxy Address
If you have GoDaddy hosting or other hosting services that require use of a proxy to talk to external sites via cURL, enter their proxy address here.
format: address:port
ie: for GoDaddy, enter: proxy.shr.secureserver.net:3128 or possibly 64.202.165.130:3128
What is the correct proxy address for Total Choice Hosting?
If you need more specifics in order to answer this, please advise.
Thanks much,
queenpictoria
TCH doesn't use a proxy for cURL connections. They would need more information on the script you are using as well as where you are trying to connect and which port numbers you needed open to make the connections.
Please open a ticket with the help desk to help you resolve the issue.
