Is the web disk the same as WebDAV? Also, the web disk application that I'm downloading doesn't run on my Mac.
Thanks,
Sandro
I never used Web Dav so I don´t what it is, but about Web disk, the documentation says:
The Web Disk allows you to easily drag and drop files to your hosting account. You can create a Web Disk login and access your Web Disk below. Once your Web Disk is configured, you can then drag and drop files to it just like they are part of your home computer. You can also navigate through the files in your hosting account just as you do the files on your local computer.
Web disks are relative to your account's home directory. The "house" icon signifies your home directory.
