I am using cgiemail with success ( www.springbreakrun.com/register.htm ). However, I want to have an alternate success page than the standard one. I would like to replace it with www.springbreakrun.com/success.htm
THe instructions simply say
"If you don't like the default page that comes up when email is successfully sent, you can specify an alternate URL using a hidden variable called ``success'' in your HTML form, e.g.
<INPUT TYPE="hidden" NAME="success" VALUE="http://www.springbreakrun.com/success.htm">
I have tried inputing this code before and after my send button, as well as randomly throughout the form :)
ANy help!
It looks like there is no page at http://www.springbreakrun.com/success.htm, and I think that is your problem.
You need to create a page that you want people to see once they register, name it success.htm, and upload it to your site.
I get the success page when typing in the URL directly. But I too get the standard plain-jane success page when I sent in a sample registration.
The "success" <input> tag should go right next to the rest of the fields that you fill in. It sounds as if you already knew that, though.
Make sure to double-check the script for the spelling of "success". Maybe it was misspelled in the script.
Looking at the source of your register.htm file, though, I cannot find the
tag anywhere. Did you take it out?
Good luck,
Dave
BTW, "Information" is misspelled on your register.htm page.
