We recently installed the SSL certificate on our website through TCH, but now our images do not display? Im new to using SSL and am not sure why this is the case.
Thanks,
-Jacques
I don't think it has anything to do with the SSL. Looking at the files, I suspect that you have added some blocking to your .htaccess (probably to prevent hotlinking) and blocked access to image files.
Try renaming the .htaccess briefly, and see if that cures the problem - if so, then at least you know what the issue is.
