Hey everyone,
I'm trying to install perl script for NETGPS. I've read post for installing script on this forum but in my case my host not allow executable script outside of the cgi-bin directory.
Hi gpratomo, welcome to our forums :)
The simple answer of course is that you will have to upload it (via FTP) into the cgi-bin directory if the host will not allow it outside of that directory.
I suspect that the program will use ports that the host has blocked though, so even if you upload it, it will not function correctly. You really need to talk through it with your current host.
[/color]PM']Hi gpratomo, welcome to our forums :)
I've talk to my host and they answer my script can execute anywhere but they prefered on /cgi-bin and upload it (via FTP). After I try several combination URL
http://www.jalawaskita.com/cgi-bin/netgps.pl
http://www.jalawaskita.com/cgi-bin/netgps....e&pw=bloggs'>http://www.jalawaskita.com/cgi-bin/netgps....e&pw=bloggs
http://www.jalawaskita.com/cgi-bin/netgps....202,11.8,E,S*07
http://www.jalawaskita.com/cgi-bin/netgps....amp;pw=bloggs33
has some error message
URL #1 produced this error:
GPSERROR:Incorrect password/unknown username.:
URLs #2, #4, and #5 produced this error:
GPSERROR:Proc error: RCV-FN1:
URL #3 produced this error:
GPSERROR:{Proc error: REM-FN1:
my filedir on script I write "/var/www/vhost/jalawaskita.com/cgi-bin" (the path of cgi-bin that I get from my host)
Edited by TCH-Don
deactivated links
Welcome to the forum, gpratomo :)
I would tackle the user / password problem first
check the file you edited to make sure of the case and spelling of the user / password.
For user/password is correct because before I use the script on my friend host and working well but after I try to upload on my host didn't work. Maybe different webhosting system.
My filedir on script I write "/var/www/vhost/jalawaskita.com/cgi-bin" (the path of cgi-bin that I get from my host). And I have permission from my host to make directory only on /jalawaskita.com, can't up level
Edited by TCH-Thomas
Deactivated links
