I'm using Joomla and it's telling me that for security reasons I need to change the settings in PHP.INI from ON to OFF. Is this something I can do or do I need to contact support?
Thanks.
George
Many thanks. The thread you referred to was also talking about RG_EMULATION and it was hard to determine exactly what was being suggested for which problem.
This sure beats the alternate suggestion posted in the Joomla forum: a separate PHP.INI in every directory to override the default.
George
The answer you seek can be found in Thomas' post.
You can also turn off globals by adding the following to your .htaccess file.
>php_flag register_globals off
