Hi
I am hopeful that someone here has used phpWebSite and can help me with my problem. In a wbpage you can add HTML code and I have done this and it works. My problem is can you use Javascripts and PHP code as well in the page sections. When I add say a Javascript to the page and save it, the script is removed from the page section. Do you need to do something special to be able to get Javascripts and PHP to work??
Any help is appreciated.
Lee
P. S. By the way the softwear is really easy to learn and if I can get my problem solved I will go this route for my next project.
Thanks Bruce
The links are helpful. The forum I found was not the one you pointed to, so maybe I can get an answer there.
Thanks again
Lee
