Prel Posted May 18, 2006 Posted May 18, 2006 Hi, This is possible create a Cron jobs for SpamAssassin Clear Spam Box in determined day and hour ? If positive somebody would know to make this or to place the code for this here ! Thank´s Quote
TCH-Bruce Posted May 18, 2006 Posted May 18, 2006 Paulo, why not just disable the spam box? If you are going to clear it without knowing if it has been checked for good emails using a cron job I don't see a need to even have it enabled. Personally, I do not use the spam box. Quote
Prel Posted May 18, 2006 Author Posted May 18, 2006 Paulo, why not just disable the spam box? If you are going to clear it without knowing if it has been checked for good emails using a cron job I don't see a need to even have it enabled. Personally, I do not use the spam box. Yes Bruce, but i have one customer that it likes to look at email Spam but it desires that it erases alone. Thank´s Quote
Prel Posted May 23, 2006 Author Posted May 23, 2006 Interesting that when removing Spam Box the number of mails spam increases in inbox, although "SpamAssassin is currently: enabled" to continue active. What it can cause this if nothing was modified only removed spambox ? Thank´s Quote
