tomowa Posted February 24, 2006 Posted February 24, 2006 Greetings, I sent my brother here to TCH. TCH techs moved the whole account from the previous webhost. All well so far, so it looks at first http://www.lowcountrymudrats.com. Yet no one can make a post to the SMF forum. The message when posting is: Database Error: Duplicate entry '0' for key 1File: /home/******/public_html/forum/Sources/Post.php Line: 1297 So I downloaded the database dump from the previous host, and using phpadmin, went to upload and inflate the dump file, and ened up with this:SQL query: CREATE TABLE `smf_attachments` ( `ID_ATTACH` int( 11 ) unsigned NOT NULL AUTO_INCREMENT , `ID_MSG` int( 10 ) unsigned NOT NULL default '0', `ID_MEMBER` int( 10 ) unsigned NOT NULL default '0', `filename` tinytext NOT NULL , `size` int( 10 ) unsigned NOT NULL default '0', `downloads` mediumint( 8 ) unsigned NOT NULL default '0', PRIMARY KEY ( `ID_ATTACH` ) , UNIQUE KEY `ID_MEMBER` ( `ID_MEMBER` , `ID_ATTACH` ) , KEY `ID_MSG` ( `ID_MSG` ) ) ENGINE = MYISAM DEFAULT CHARSET = latin1 MySQL said: #1064 - You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'DEFAULT CHARSET=latin1' at line 11 The MySQL version at the previous host was MySQL 4.1.14-standard Here at TCH server 110 it is MySQL 4.0.25-standard I believe this is the problem. Can anyone shed any light on this, and if this is the problem, can/how it be rectified? I have been through the SMF to no avail...... Thanks for any thoughts, Tom Quote
TCH-Bruce Posted February 24, 2006 Posted February 24, 2006 Sorry Tom, I don't know the answer. Hopefully someone will be along soon that can help. Quote
tomowa Posted February 24, 2006 Author Posted February 24, 2006 Thanks Bruce, I just got it going Now I can go to work! This was it: It was a MySQL database issue, the 'old' server version of MySQL was MySQL 4.1.14-standard The 'new' server MySQL version was MySQL 4.0.25-standard, an older version. Had to remove references to 'DEFAULT CHARSET=latin1' and 'COLLATE utf8_unicode_ci' in the MySQL dump, then upload the dump again. All works now I actually ended up at WordPress forum, to find this solution http://wordpress.org/support/topic/61160. Quote
