Here's the PHP code if you need it:
<?php
$Id: header.php,v 1.42 2003/06/10 18:20:38 hpdl Exp $
osCommerce, Open Source E-Commerce Solutions
http://www.oscommerce.com
Copyright © 2003 osCommerce
Released under the GNU General Public License
// check if the 'install' directory exists, and warn of its existence
if (WARN_INSTALL_EXISTENCE == 'true') {
if (file_exists(dirname($HTTP_SERVER_VARS['SCRIPT_FILENAME']) . '/install')) {
$messageStack->add('header', WARNING_INSTALL_DIRECTORY_EXISTS, 'warning');
// check if the configure.php file is writeable
if (WARN_CONFIG_WRITEABLE == 'true') {
if ( (file_exists(dirname($HTTP_SERVER_VARS['SCRIPT_FILENAME']) . '/includes/configure.php')) && (is_writeable(dirname($HTTP_SERVER_VARS['SCRIPT_FILENAME']) . '/includes/configure.php')) ) {
$messageStack->add('header', WARNING_CONFIG_FILE_WRITEABLE, 'warning');
// check if the session folder is writeable
if (WARN_SESSION_DIRECTORY_NOT_WRITEABLE == 'true') {
if (STORE_SESSIONS == '') {
if (!is_dir(tep_session_save_path())) {
$messageStack->add('header', WARNING_SESSION_DIRECTORY_NON_EXISTENT, 'warning');
} elseif (!is_writeable(tep_session_save_path())) {
$messageStack->add('header', WARNING_SESSION_DIRECTORY_NOT_WRITEABLE, 'warning');
// check session.auto_start is disabled
if ( (function_exists('ini_get')) && (WARN_SESSION_AUTO_START == 'true') ) {
if (ini_get('session.auto_start') == '1') {
$messageStack->add('header', WARNING_SESSION_AUTO_START, 'warning');
if ( (WARN_DOWNLOAD_DIRECTORY_NOT_READABLE == 'true') && (DOWNLOAD_ENABLED == 'true') ) {
if (!is_dir(DIR_FS_DOWNLOAD)) {
$messageStack->add('header', WARNING_DOWNLOAD_DIRECTORY_NON_EXISTENT, 'warning');
if ($messageStack->size('header') > 0) {
echo $messageStack->output('header');
<table border="0" width="100%" cellspacing="0" cellpadding="0">
<tr class="header">
<td valign="middle"><?php echo '<a href="' . tep_href_link(FILENAME_DEFAULT) . '">' . tep_image(DIR_WS_IMAGES . 'newdebutantelogo.jpg', 'Debutante Clothing') . '</a>'; ?></td>
<td align="right" valign="bottom"><?php echo '<a href="' . tep_href_link(FILENAME_ACCOUNT, '', 'SSL') . '">' . tep_image(DIR_WS_IMAGES . 'header_account.gif', HEADER_TITLE_MY_ACCOUNT) . '</a>  <a href="' . tep_href_link(FILENAME_SHOPPING_CART) . '">' . tep_image(DIR_WS_IMAGES . 'header_cart.gif', HEADER_TITLE_CART_CONTENTS) . '</a>  <a href="' . tep_href_link(FILENAME_CHECKOUT_SHIPPING, '', 'SSL') . '">' . tep_image(DIR_WS_IMAGES . 'header_checkout.gif', HEADER_TITLE_CHECKOUT) . '</a>'; ?>  </td>
</tr>
</table>
<table border="0" width="100%" cellspacing="0" cellpadding="1">
<tr class="headerNavigation">
<td class="headerNavigation">  <?php echo $breadcrumb->trail(' » '); ?></td>
<td align="right" class="headerNavigation"><?php if (tep_session_is_registered('customer_id')) { ?><a href="<?php echo tep_href_link(FILENAME_LOGOFF, '', 'SSL'); ?>" class="headerNavigation"><?php echo HEADER_TITLE_LOGOFF; ?></a>  |  <?php } ?><a href="<?php echo tep_href_link(FILENAME_ACCOUNT, '', 'SSL'); ?>" class="headerNavigation"><?php echo HEADER_TITLE_MY_ACCOUNT; ?></a>  |  <a href="<?php echo tep_href_link(FILENAME_SHOPPING_CART); ?>" class="headerNavigation"><?php echo HEADER_TITLE_CART_CONTENTS; ?></a>  |  <a href="<?php echo tep_href_link(FILENAME_CHECKOUT_SHIPPING, '', 'SSL'); ?>" class="headerNavigation"><?php echo HEADER_TITLE_CHECKOUT; ?></a>   </td>
</tr>
</table>
<?php
if (isset($HTTP_GET_VARS['error_message']) && tep_not_null($HTTP_GET_VARS['error_message'])) {
<table border="0" width="100%" cellspacing="0" cellpadding="2">
<tr class="headerError">
<td class="headerError"><?php echo htmlspecialchars(urldecode($HTTP_GET_VARS['error_message'])); ?></td>
</tr>
</table>
<?php
if (isset($HTTP_GET_VARS['info_message']) && tep_not_null($HTTP_GET_VARS['info_message'])) {
<tr class="headerInfo">
<td class="headerInfo"><?php echo htmlspecialchars($HTTP_GET_VARS['info_message']); ?></td>
</tr>
</table>
<?php
