I recently purchased 4 domain names from you and parked all 4 on my site bruceshobbies.com. The domains in question are: rcbikeshop.com, rcbikestore.com, rcmotoshop.com, and rcmotostore.com. Looking at the DNS records they appear to be in your ns1 and ns2 name servers. The issue I am having is that they don't appear to be propagating to other servers correctly. Looking at the dnsstuff.com lookup results I get:
DNS Lookup: rcmotoshop.com A record
Generated by www.DNSstuff.com
How I am searching:
Searching for rcmotoshop.com A record at e.root-servers.net [192.203.230.10]: Got referral to K.GTLD-SERVERS.NET. [took 72 ms]
Searching for rcmotoshop.com A record at K.GTLD-SERVERS.NET. [192.52.178.30]: Got referral to dns3.totalchoicehosting.com. [took 106 ms]
Searching for rcmotoshop.com A record at dns3.totalchoicehosting.com. [207.44.236.88]: Server failure! [took 119 ms].
Answer:
Server failure. There's a problem with the DNS server for rcmotoshop.com.
I tried tis lookup several times and got similar results. The lookup appears to directed to dns3 and dns4 and NOT ns1 and ns2. Is this a mistake on your part or have I not waited long enough for the domains to propagate?
Thanks,
Bruce
You need to login to the domain name registration side, and change the DNS (Nameservers) from;
dns3.totalchoicehosting.com and
dns4.totalchoicehosting.com
to
ns1.totalchoicehosting.com and
ns2.totalchoicehosting.com
to
I just checked and they are set to dns3 and dns4 on the "domain name registration side". But in the "Edit DNS Zone" of my reseller control panel it shows ns1 and ns2. Seems strange that I have the option of changing name servers in 2 different places and they show different values.
So which one is correct?
Bruce
