All of a sudden today, the date modified is displaying 12/1/2004. I've tried searching the Globalscape forums, and google, but can't find any reference to the date showing up incorrectly, or how to fix it.
Has anyone had this problem? Any solutions?
Thanks alot,
Miriam
The times on the FTP server are in UTC, which is (I believe) 8 hours ahead of your local time. At the time of your post (11/30 5:52 PM), UTC time was 12/01 01:52 AM. If you uploaded a new file or modified a file after 4:00 PM local time, the modified date on the server (in UTC) would show 12/01. The date is correct, so there is nothing to fix.
I just re-read your post and noticed that you posted "2004" for the date that the FTP server is showing. If you really meant "2004" instead of "2005", that would indicate to me the date on the server is not set correctly, and you should probably submit a ticket to the Help Desk and have them look into it.
Yes, it really says 2004. I will submit a ticket. Thanks.
Added:
I submitted the ticket and they said the date on the server is correct. I re-opened the FTP program and looked at the files I had uploaded last night, and now they say 12/1/2005. Poltergeists? UFO's? It's certainly an unexplained phenomenon. At least I'm back in the right year.
