I'm having a heck of a time getting my email up and running here. I can get mail coming in just fine, but I can't send any mail out. I've tried all the combinations of name@domain.com and name+domain.com and so forth, but I keep getting this -
"Logging into mail.domain.com SMTP server...
Could not connect to mail.domain.com SMTP server
501 Invalid base64 data
No messages sent"
I use Poco Mail, can't stand Outlook. Hopefully someone has an idea or hint, or can point me to the tutorial (I swore I saw one but now can't find it...) Thanks!
I've never used Poco Mail so I am not sure of the configuration options but you need to validate yourself to send email.
I found a PDF manual online for Poco Mail.
On the Outgoing Tab: Make sure to check off the Use Outgoing Server Authentication box, and fill in the appropriate username and password.
Set the port for SMTP to 26
Hopefully that will get you going.
I got it going - Turns out under Authentication Type you need to pick Login, not Plain.
In any case, working like a charm now, thanks TCH!!
