Hello every one
I tried to install Advanced Guestbook 2.3.4 but I have this error message
Warning: mysql_connect(): Access denied for user: 'root@localhost' (Using password: NO) in /home/medwani/public_html/guestbook/lib/mysql.class.php on line 30
Any one can help I will appreciate that
Thanks in advance
Simon
Welcome to the forums Simon
here are my notes for using a database
-- database connect ----
Be sure that in MySql you
1 - created the database
2 - created a user
3 -added the user to the database (go back to MySql and find the Add user
select the user and database, and then Add user to database)
Then to connect to the database in a script use:
host: localhost
database: yourCpanelName_databaseName
user: yourCpanelName_databaseUser
password: mypassword
* Note password is just as the password,
do not add the CpanelName to it.
Don
Thanks so much for your notes
I have already created the database and the user
I have submitted such info in install.php file. everything went smooth. however when I was done with the instalation and redirected to the admin.php file I got the message I submitted above
Any further help is highly appreciated
The error message indicates that install script is not connecting to the database
You said you created the database and a user
but did not say that you added the user to the database (step 3)
if you did then I would double check the spelling and case for the connection info
Check the admin/config.inc.php file
so the connection looks like this
<?php
/* database settings */
$GB_DB["dbName"] = "yourCpanelName_databaseName";
$GB_DB["host"] = "localhost";
$GB_DB["user"] = "yourCpanelName_databaseUser";
$GB_DB["pass"] = "*******";
there is not much else unless the zip file you downloaded is corrupt.
You might try another download.
