Hi everyone,
How do I find information about file names like * WysiwygPro
* _private
* _vti_bin
* _vti_cnf
* _vti_log
* _vti_pvt
* vti_txt
* cgi_bin
* chat
* images
and more... and what kind of files in each files that I suppose to add? also what kind of files is required in each folder. By the way, I'm gonna get all scripts from hotscripts.com
is there's available AuthPro in TCH? like users sign in to my hosting site? or I gotta have something from hotscripts?
Well hope you suggest me about folder names. I'm getting learn how to use cpanel but I need more helps.
I can tell you that any folder name that starts with _... (_vti_bin, etc.) is for use with Micro$oft FrontPage. If you don't use Frontpage, then you can safely turn off the Frontpage extentions in your CPanel. The cgi-bin folder is used for your cgi scripts. Not sure what software you installed, but I'm assuming that the chat folder is left over from that. And the images folder is a commonly used folder to store images.
There shouldn't be any file names that contain what you're asking. Hope this helps!
