androoze Posted September 14, 2005 Posted September 14, 2005 What is a good (free) program that will monitor my memory usage on-screen?? Where can I find more info about such programs? Thanks!!! P.S. OS=XP Quote
Madmanmcp Posted September 14, 2005 Posted September 14, 2005 Windows comes with one in Task Manager. Press Ctrl-alt-del click on the PERFORMANCE tab it also puts a little icon in the Systray to show usage. If you search the web you should find hundreds that will do the job you want. Quote
