julie Posted September 2, 2005 Posted September 2, 2005 When viewed in Firefox, my banner has a weird white block character at the right end, like a space is highlighted. It doesn't show up in IE and I can't figure out how to make it go away. Any ideas? http://www.eatitandloveit.com Quote
TweezerMan Posted September 2, 2005 Posted September 2, 2005 Looking at the source HTML, you have this code in your page: ><div id="banner"> <h1><a href="http://www.eatitandloveit.com/" accesskey="1"><img alt="eatitandloveit.gif" src="http://www.eatitandloveit.com/archives/images/eatitandloveit.gif" width="800" height="70" / border =" 0"></a></h1> <h2></h2> </div> Because the <h2> element is inside the 'banner' div, this style from your stylesheet is being applied to it: >#banner h2 { font-size: x-small; display: inline; padding-left: 10px; border-left: 5px solid #fff; } What you're seeing in Firefox is a 5px wide white border on the left of where the <h2> element is displayed (even though there is no text). To make the border 'disappear', you can style the border color so it is the same as the background color: >border-left: 5px solid #006; You could also just remove the border-left style. Hope this helps... Quote
julie Posted September 2, 2005 Author Posted September 2, 2005 ok thanks - i fixed that part. but i wanted to get rid of the padding above, below, and to the left of the image. it looks right in firefox, but in IE there is still a small blue line below that i dont want to be there. Quote
TweezerMan Posted September 3, 2005 Posted September 3, 2005 What you're seeing is the #banner div extending just slightly below the image in IE. The following seems to fix the display in IE without disturbing the display in Firefox: In your stylesheet, set the height for the #banner div equal to the image height. >#banner { font-family: Verdana, Arial, sans-serif; color: #fff; background-color:#006; text-align: left; height: 70px; } Then add a style to set a negative bottom margin for the image, just enough to make the 'line' go away: >#banner a img { margin-bottom: -3px; } Quote
