CaptainCrunk Posted August 10, 2005 Posted August 10, 2005 I get this message everytime I try to connect with my ftp account: An FTP error occured- cannot make connection to host. The remote host cannot be found. What should I do??? I forgot the information I have to fill out but I did. I dont know if its wrong or if something else is wrong. I am using marcomedia dreamweaver. Quote
abinidi Posted August 10, 2005 Posted August 10, 2005 Back in my Dreamweaver days, I think I remember that the error message you get is pretty specific. So, if your username and password are wrong, it will tell you that. Since the error says it can't make a connection to the host, my guess is (1) you have typed in the informaiton incorrectly for your FTP location/info or (2) you have some type of firewall that is blocking FTP connections. I think you should first check your FTP information in the Site settings area. If you are sure that is correct, then you should check to see if it is a firewall issue. Quote
CaptainCrunk Posted August 10, 2005 Author Posted August 10, 2005 Thanks for the quick reply. Nothing to do with the firewall. I checked, but before I used TCH I was witha different hosting company and it worked. I dont know whats wrong with it. Quote
TCH-Don Posted August 10, 2005 Posted August 10, 2005 Has the domain name propagated yet? Not a DW user but you may have to use the IP address in your welcome e-mail until the name resolves to your server. just a thought. Quote
CaptainCrunk Posted August 10, 2005 Author Posted August 10, 2005 TCH live support helped me fix it. Quote
TCH-Don Posted August 10, 2005 Posted August 10, 2005 Glad you are all set. If it might help another family member in the future can you tell us what it was? Quote
CaptainCrunk Posted August 10, 2005 Author Posted August 10, 2005 I had to set in the field: ftp host: "Whatever your domain is" So I didnt fill it out completely. Quote
stevevan Posted August 10, 2005 Posted August 10, 2005 Don't ya just HATE that?!? Glad ya got it working! Quote
TCH-Don Posted August 10, 2005 Posted August 10, 2005 Thanks for sharing. you never know when this will help the next family member. Hope you are getting settled in ok Quote
