Imagine my surprise when I'm reviewing logs, and find someone getting a 200 on (mysite)/cgi-sys/guestbook.cgi.
I don't have a guestbook (I thought). Never installed the guestbook scripts. Don't even want the script availble to poke at.
I cleaned out everything in my /cgi-bin already, but the guestbook.cgi is still publicly accessible.
Went through cPanel, and verified that there were no databases that I didn't explicitly create.
How can I remove this? (How was it installed?!)
If you have cleaned out everything you can think of, html-files, folders, databases or whatever that can cause this and its still showing, please open a ticket to the helpdesk so they can check :thumbup1:
If you go into your cpanel > cgi scripts
you will see Simple Guestbook
this is a server script for you to use or not.
It looks like someone was fishing to see if you were using it.
