Hi!
Just set up a blog at Blogger.com but hosting it on my TCH account.
I have set it up, but for some reason the blog is not showing.
Can someone check my settings and tell me where I might have gone wrong?
The following are my settings (actual domain name changed)
FTP Server: ftp.mydomainname.com
Blog URL: http://www.mydomainname.com/polyphonicjourney/
FTP Path: /home/cpanelusername/www/public_html/
Blog Filename: index.html
When I publish the blog, it publishes successfully, but then when I "View Blog" it goes to an error 404 page.
Is it possible that I have the FTP Path wrong? In the setup notes they say it should be something like: /www/public_html/
When I emailed TCH support they said the FTP Path for my server is /home/cpanelusername
What should I have put?
Thanks for any assistance you can provide.
If you want the actual URL to the blog, please PM me.
Edited by webgyrl
Also, not sure if this helps. I didn't create the directory "polyphonicjourney" before I made the blog and I can't seem to find the directory on my server.
Should I create this directory in the public_html directory?
Edited by webgyrl
Ok.. I fixed it.
I did need to create the directory and I had the FTP path wrong.
It should have been: public_html/polyphonicjourney
Hope this info helps someone else!
I'm glad you were able to get it working! :)
The www and public_html directories are the same directory, as www is a link to the public_html directory. The '/home/cpanelusername' part of the server path is hidden from FTP, so you would normally omit that from an FTP path setting.
Thanks David.
Yeah I was a bit confused about the correct path... but got it figured out.
Hope you are doing great!
Edited by webgyrl
