webgyrl Posted April 24, 2005 Posted April 24, 2005 Hi gang, Tweaking my latest design and decided to add in a page that has iFrame scrollers as an option to use for sections that have a lot of text. Everything has been going alright, except now I have an issue with IE 6 and the iFrame scrollers. Just FYI, I am using 4 Level's iFrame Suite plugin in Dreamweaver to add the scrolling behavior and iFrames into the design. I am going to email them as well about the issue, but not sure it is within the scope of support there, so I figured I'd ask my TCH Family for some input, cuz you guys are always so helpful and I learn a lot here. The Design in question: PAGE 1 (non-template page) www.natfunkmusic.com/mbstia/testplainscroll.htm This is a page cretated in Photoshop > Sliced in Fireworks and exported to Dreamweaver. Firefox 1.0.3 - scrollers work fine and text looks fine IE6 - Scrollers just go up and down 1 pixel. They do not scroll properly. PAGE 2 (DWT template page) www.natfunkmusic.com/mbstia/test_scroll.htm This is a design cretated in Photoshop > Sliced in Fireworks and exported to Dreamweaver and made into a DWT (Dreamweaver Template) Problems: Firefox 1.0.3 - scrollers work fine but for some reason the HEADING template editable region breaks up the design a bit. Because the design does not break up in the non-template file, I have a feeling that the design break up has something to do with inputting an editable region in the template file. I will have to play around with that to see if I can fix it. Scrollers work fine IE6 - Scrollers just go up and down 1 pixel. They do not scroll properly. The design part looks fine. Any ideas where I can look to tweak to fix these issues? Thanks Quote
webgyrl Posted April 24, 2005 Author Posted April 24, 2005 (edited) Ok, this is interesting. Just checked the design in Firefox again and the scrollers aren't working in either browser (IE 6 or Firefox) I got the webdev tool for Firefox and there is are JS errors showing: Error: uncaught exception: Permission denied to get property Window.frame Error: uncaught exception: [Exception... "Component returned failure code: 0x80004005 (NS_ERROR_FAILURE) [nsIObserverService.removeObserver]" nsresult: "0x80004005 (NS_ERROR_FAILURE)" location: "JS frame :: chrome://browser/content/browser.js :: Shutdown :: line 831" data: no] What do those errors mean? Edited April 24, 2005 by webgyrl Quote
webgyrl Posted April 25, 2005 Author Posted April 25, 2005 (edited) Got an email back from the iFrame Suite developer. He told me to take out the DocType in the pages that were being called into the iFrame and that has fixed the issue. Now if I can figure out why adding in that editable template Header region is breaking up my design in Firefox, I'll be ready to rock and roll... Edited April 25, 2005 by webgyrl Quote
TCH-Don Posted April 25, 2005 Posted April 25, 2005 glad you got it working. it looks good in firefox, very impresive. but I see thin lines around the round scroll buttons in iE. Quote
webgyrl Posted April 25, 2005 Author Posted April 25, 2005 glad you got it working. it looks good in firefox, very impresive. but I see thin lines around the round scroll buttons in iE. <{POST_SNAPBACK}> Thanks Don. I do have to figure out what sort of DocType will work as I have read it's really not good to leave the DocType completely out. As for the lines, grrrr.. they have been a source of utter frustration. When I create the Editable Region for the Header in the Template file, it doest that. When I just leave it and don't make that a Dreamweaver Template, it renders fine without the line. I am fiddling with it to see if I can get it to work. Quote
webgyrl Posted April 25, 2005 Author Posted April 25, 2005 (edited) Interesting... iFrame misalignment This has me confused: There is a site I desgined a few months ago (without the 4 Level Dreamweaver plug-in): http://www.deilsys.com This uses iFrames and regular scroll bars. When I check it in the Mac Browser checker, it comes up fine with no misalignment of the iFrame. Here is the code: DEIL SYSTEMS SITE ><iframe id="frame" name="frame" width="610px" height="285px" align="left" frameborder="no" scrolling="yes" src="specials.htm">Your browser does not support iFrames. Please upgrade your browser so you have the latest version available.</iframe> The plugin I used to create the iFrames this time rendered the following code: MBSTIA SITE ><iframe id="frame" name="frame" style="position:absolute; width:675px; height:285px; top:338px; left:150px; z-index:1; background-color: #FFFFFF; layer-background-color: #FFFFFF; border: 1px none #000000;" frameborder="no" scrolling="no" src="../mbstia/test_scrollins.htm">Your browser does not support iFrames. Please upgrade your browser to the latest version.</iframe> http://www.natfunkmusic.com/mbstia/test_scroll.htm I tried to use the old (non-plugin) code in place of what I had for the iFrame code for the MBSTIA site to see if that would fix the misaligned iFrame: ><iframe id="frame" name="frame" width="675px" height="285px" align="left" frameborder="no" scrolling="no" src="../mbstia/test_scrollins.htm">Your browser does not support iFrames. Please upgrade your browser so you have the latest version available.</iframe> But as you can see when you check it, it is still misaligned. Why is that happening? BTW I figured that the screen resolution has nothing to do with the misaligment as I checked it on 15,17 and 19 Inch Monitors in IE and Firefox and the iFrame is aligned fine. It just does not align on a Mac. Strange. Edited April 25, 2005 by webgyrl Quote
TCH-Don Posted April 25, 2005 Posted April 25, 2005 I did find a nice site to show all the options for iframes maybe set margins to zero http://www.htmlcodetutorial.com/frames/_IFRAME.html Quote
webgyrl Posted April 28, 2005 Author Posted April 28, 2005 I did find a nice site to show all the options for iframesmaybe set margins to zero http://www.htmlcodetutorial.com/frames/_IFRAME.html <{POST_SNAPBACK}> Hey Don thanks for the link to that site. I did set the margins to 0. It's weird because I used an older bit of code I had for iFrames and that is working fine now. I am not sure why the iFrame Suite code messes up the alignment. Still looking in to it. Someone told me the other day that my using scrollers would put a lot of web users "off". Do you think this is true? Quote
