MOONDAWG2005 Posted April 24, 2005 Posted April 24, 2005 I want to change the color of the header and catagory, From the blue ( as seen above on this site)Is that a skin? or how would I change the color of the header and catagory bars. does it takes a ftp client to do that also or can I do it in the controls? Thanks Quote
TCH-Andy Posted April 24, 2005 Posted April 24, 2005 Hi, I assume you are taking about a forum - is that invision forum? which version? Quote
MOONDAWG2005 Posted April 24, 2005 Author Posted April 24, 2005 Yes it is Invision Power Board(U) v1.3 What do I need to do? To change the color of my header and catagory bars. Thanks Quote
stevevan Posted April 24, 2005 Posted April 24, 2005 You might want to look at this page for some ideas and other helpful hints. Quote
TCH-Andy Posted April 24, 2005 Posted April 24, 2005 Good link Steve If you login to the admin control panel, Then you should see "Skins and Templates" on the left hand side. Click on that and "Manage skin sets". You should then see an option to edit "colours". What is your domain name? And I'll take a closer look at things for you. Quote
MOONDAWG2005 Posted April 24, 2005 Author Posted April 24, 2005 thanks. I will pm you my site. Thanks Quote
