I have installed Agora from cPanel and now I want to remove it. I think I will use osCommerce instead after reading posts on this forum.
There is no remove option in cPanel, can I just remove the directory that I installed it in??
Thanks
Lee
Ok just installed angora cart,
it did not setup a database
it uses a data file inside the folder where you installed it
so just use file manager to remove the folder.
Thanks Bruce and Don
I did just remove the folder.
Thanks again
Lee
