Sign in to follow this
scottsgravy
Cron Command Help Please
I have a script I want to run: cron-lynx.sh
Its located here: /public_html/scripts/
Using the Standard Cron Manager in cpanel, what do I enter in "Command to run."
Thanks.
Share this post
Link to post
You would enter: /home/yourcpanelname/public_html/scripts/name-of-script
Thanks. That path worked.
I'm getting an error:
/bin/sh: line 1: /home/controlpanelname/public_html/scripts/cron-lynx.sh: Permission denied
The script in cron-lynx.sh is:
#!/bin/sh
/usr/bin/lynx -source http://www.scottsgravy.com/cron.php > /dev/null 2>&1
Share this post
Link to post
Scott, you may also want to run a simpler cron command, such as
>php -q /home/yourusername/public_html/cron.php
That way you don't need an extra shell script.
Moving for organization.
Share this post
Link to post
Thanks, I tried that and got a bunch of errors. Maybe it doesn't work with Drupal?
The other way works though. Thanks everyone for your help. :P
Share this post
Link to post
Well, I'm not sure how Drupal needs the script to be run but either way should work just fine. If you got errors when using the method I suggested, you probably got the same errors when using the shell script but those are redirected to /dev/null, so you won't see them.
Anyway, glad you got it working :thumbup:
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
