Hello,
I need a unique IP address for my website. Can you provide one?
I am willing to pay extra for a unique IP address. Please tell me the cost for a static IP, on a per month basis or on a per year basis.
Can I get it for free?
You do realize there is a difference between a dedicated IP (vs. shared with other domains) and a static IP (vs. a dynamic one). With a hosting plan here, you will (without asking) get a static, but shared IP address.
Unfortunately, I can't answer whether you can buy a dedicated IP -- though you can certainly buy a dedicated server.
Please tell the cost and I will pay for it. I desparately need a dedicated IP.
Right on the home page for TCH, there is a link for dedicated hosting. Looks like the dedicated unmanaged plan would suit your needs, at $229/mo. They also have an add-on for 5 IP addresses at $7/mo.
I don't know if they will do shared hosting with dedicated IP. Is that what you're looking for??
Also, it *might* help if you said *why* you believe you need a dedicated IP -- chances are someone here (not me) has been down the road before and might know a workaround to whatever issue you're facing.
We follow ARIN (arin.net) guidelines.
The only sites that will be sold dedicated IP's are -
Reseller accounts that use Private Name Servers
SSL Sites
Anon FTP Sites (Dedicated Server's Only)
That is it.
We will NOT issue dedicated IP's under any other circumstances.
Hey--
I went to the ARIN website and read some of the policies. I confess I didn't understand more than about half of it! Are you aware of any sites that spell some of the logic and the policies out in simpler terms?
Thanks!
--Beth
Suppose I need an SSL certificate, then what will be the cost for (shared hosting) dedicated IP?
I think SSL is provided free of charge at TCH. Am I right?
