pcgoliath.com Posted January 17, 2005 Posted January 17, 2005 I want to take my template and when someone clicks on motherboards it will load the motherboard category into the right side main box of the page. In a sense, i want the middle of the stock oscommerce page to be on the right main section of my template. Any ideas on how to do this? http://www.pcgoliath.com/index2.php is the template/store http://www.pcgoliath.com/store is the oscommerce part Let me know if you can help, and any help is much appretiated. I can even add you to a links section for your website if you want. Thank you all so much and god bless. - George http://www.pcgoliath.com Owner Quote
TCH-RobertM Posted January 17, 2005 Posted January 17, 2005 pcgoliath I am trying to do something very similar to what you are trying to accomplish... I cannot help you yet but in a day or two I will be digging in to the code of Oscommerce to make it fit within the site I am building. If I find a quick solution I will message you then as well. Should you find a way to do it I would appreciate a post here if you dont mind. Good Luck Robert I am currently looking here for information http://www.oscommerce.info/ Quote
pcgoliath.com Posted January 17, 2005 Author Posted January 17, 2005 Thanks alot. Let me know and i will help you the same, if i find out. I am very good with oscommerce or templates separate but never tried to stick them together.. Iframe targets would work but would look horrible.. Let me know... thanks. Quote
TCH-RobertM Posted January 17, 2005 Posted January 17, 2005 I sure will, I just finished base install of Oscommerce I have never played with it before so I am learning as I go. I am setting up catagories now and will let you know as I progress once I get something to show you I will , Thanks Quote
pcgoliath.com Posted January 17, 2005 Author Posted January 17, 2005 Great thanks for all your help Quote
pcgoliath.com Posted January 17, 2005 Author Posted January 17, 2005 I have tried it over and over again but i cant find a way to get the index into the template without using iframe target's Quote
TCH-RobertM Posted January 17, 2005 Posted January 17, 2005 have you tried to ask this in the OsCommerce Forum pcgoliath ? I asked a question there earlier and found them to be very resourceful and pretty quick with helping me, here is the link http://forums.oscommerce.com/ I am still working through my initial setup issues ...sorry I cant be of more help right now Quote
pcgoliath.com Posted January 18, 2005 Author Posted January 18, 2005 i did.. no help.. ty... let me know Quote
pcgoliath.com Posted January 18, 2005 Author Posted January 18, 2005 still working with it but this looks like what will help me convert to a template http://www.oscommerce.com/community/contributions,1524 Quote
TCH-RobertM Posted January 18, 2005 Posted January 18, 2005 I will have to take a look at that and see. I am also looking into the Zen cart seeing if it may be easier to customize thank you for that info PCGoliath Quote
