MyDisplayName Posted December 14, 2004 Posted December 14, 2004 I have been using Outlook to check my email that I have set up through my website and lately it has stopped working for the most part. Also I receive an error from time to time when trying to use Horde to check my email (but I forgot to copy down the error message). In Outlook the error message I am getting is "Task 'webmail.brettwho.com - Receiving' reported error (0x800CCC0F) : The connection to the server was interrupted.....The server responded: +OK 4469723 octets'" Does anyone have any idea what could be wrong? It was working fine for weeks and I didn't change anything and now it decides to work only once in a while. Thanks in advance for any help! Quote
TCH-Rob Posted December 14, 2004 Posted December 14, 2004 Are you using IMAP? What are your Outlook settings? Quote
TCH-Don Posted December 14, 2004 Posted December 14, 2004 We do not have access to your account here, but you can open a helpdesk ticket to have the techs check your e-mail account to eliminate that as a possibility. Is your connection to the net solid? Quote
MyDisplayName Posted December 14, 2004 Author Posted December 14, 2004 Are you using IMAP? What are your Outlook settings? IMAP? I'm afraid I don't know what that is. What settings are you wondering about? The incoming and outgoing servers are "webmail.brettwho.com". Incoming server port 110. Outgoing server port 26. It's set to send/recieve every 5 mins. Server Timeout is 1minute. Quote
MyDisplayName Posted December 14, 2004 Author Posted December 14, 2004 We do not have access to your account here,but you can open a helpdesk ticket to have the techs check your e-mail account to eliminate that as a possibility. Is your connection to the net solid? My connection is pretty solid. I have trillian running and my connection to AIM isn't dropping while I cannot connect to my email. But I don't know if that is a good 'control'. There doesn't seem to be a problem sending emails, just the recieving part. Quote
MyDisplayName Posted December 15, 2004 Author Posted December 15, 2004 try mail.brettwho.com instead That didn't help. Quote
TCH-Don Posted December 15, 2004 Posted December 15, 2004 You could open a helpdesk ticket to have the techs look at your e-mail, they can try it out to see if there is anything wrong with it. Quote
MyDisplayName Posted December 15, 2004 Author Posted December 15, 2004 You could open a helpdesk ticket to have the techs look at your e-mail,they can try it out to see if there is anything wrong with it. Yeah that's what I will do. I just figured I would ask here first before I bothered the techs with something that might have been an easy fix. Thanks for the help guys. Quote
