I'm trying to create a new database via phpMyAdmin. Until now, I've done it through the cPanel interface, but I'd like to be able to do it all in one spot -- creation and maintenance and such.
What I'm doing is going to phpMyAdmin. Then, on the front page, in the MySQL column, the first option is "Create New Database" with a field for a database name. Typing anything in and then hitting "Create" results in the following page:
>SQL-query:
CREATE DATABASE `mcc3d_test`;
MySQL said:
#1044 - Access denied for user: 'mcc3d@localhost' to database 'mcc3d_test'
How can the localhost be denied access? :dance: Is there a setting I missed somewhere? Thanks.
You need to create the database in Manage mySQL (in cpanel). You also need to assign a user to the database there. You can then use PHPmyAdmin to add data into the database.
Yeah, that's the way I've been doing it. There's no way to bypass the manage SQL step and do the management through phpMyAdmin?
You may already know this, but this is for others.
You do the management in phpMyAdmin
You have to create the database in Manage Mysql
its very easy
type a name click add DB
create user/password
Add user to database
then you can use or manage in phpMyAdmin
