awhfy99 Posted September 17, 2004 Posted September 17, 2004 I was having all kinds of minor problems getting phpauction to update, but thanks to the forum and the help desk, I finally got on the right tract. Only wasted a few days trying to get a script that was meant for a dos server to work here. Oh well, life is for learning. Come to find out, the update file was named cron.php (go figure)! To get the php file to run in cron, I did have to add php in front of the full path. php /home/alltherestofthepath/cron.php That little tidbit was found on one of the other discussions here, so again, thanks for a good forum! Rock Sign Quote
TCH-Don Posted September 17, 2004 Posted September 17, 2004 And thank you for the update. This type of feedback always helps others. Thats what makes us family Quote
lobos Posted October 1, 2004 Posted October 1, 2004 I just registered on this forum for the sole purpose of thanking you for this info - I am not a noob to this sort of stuff, but it has taken me hours of searching google to come up with a solution to executing a php file with cron on cpanel. So simple all you need to do is put php /home/alltherestofthepath/cron.php in the "command" box. ...so simple it is painfull Thanks... Quote
